  • Latest SGBikeMart Adverts
  • Yamaha's entry for the Class 2B street bike market comes in the form of the Yamaha MT-15, or Yamaha MTN155 if you are being technical. Like its elder siblings, the MT-07, MT-09, etc, it adopts the MT moniker and goes by the tagline - "The Dark Side of Japan". Its name is not just the only thing that takes after the much more powerful motorcycles however, as you can tell from its looks, that a lot of styling and design cues are also inspired from the larger Class 2 motorcycles. This two wheeler is more focused on design and positioned as a street racer.
    Yamaha Singapore Official Distributor
    Hong Leong Corporation - Yamaha Motor Singapore
    Address: 178 Paya Lebar Rd, Singapore 409030
    Phone: 6749 0588
    580b57fcd9996e24bc43c543.png.000f4022d5be84603278d03a281c4770.png Click HERE to ENQUIRE now on ANY Yamaha Motorcycles! Special price for SBF members! 580b57fcd9996e24bc43c543.png.000f4022d5be84603278d03a281c4770.png
    This is the naked or street version of Yamaha R15 (which we have reviewed here) with slightly different capabilities. The overall look of the bike remains same as MT series and the bike is more oriented to city like driving conditions and priced at S$14,000 (including COE, excluding insurance) prices itself right up against similar offerings from Honda and other Japanese manufacturers. Will MT15 carve out a niche for itself? Let’s find out.
    Styling & Design
    Well, as soon as you see the bike, your eyes get stuck on it. The bike looks muscular and its headlamp makes it more special. The headlamp cluster is equipped with twin-LED position lamps which gives the impression of eyes and a LED projector lamp positioned beneath it.  Hence it appears to resemble Transformer (fictional character) and makes it unique in this segment.
    The 10-litre tank is shaped in such a way that it provides a muscular look to the bike and air-intakes further accents this trait too. The handlebar is a single-unit and keeps you in an upright and comfortable riding position, unlike the racing position on the Yamaha R15. The quality of bar end weights and switches are excellent and goes to show the excellent qualities of the Yamaha brand.
    Coming to the rear of the bike, the tail lamp is integrated at the rear of the seat. The exhaust sound complements the feel of a sports bike and has a nice tune to it. The single-seat design and rear fitted foot pegs give you a slightly more aggressive riding position on the bike but even riding on longer journeys, the ride is very compliant and smooth. The seat though is plushy for the rider enough so that you could actually go long-distance touring on the MT-15.
    Engine & Performance
    Engine Type: Liquid -cooled , 4 -stroke ; SOHC , 4 -valves
    Displacement: 155 cm3
    Max. Power: 13.9 kW . at 10000 rpm
    Max. Torque: 14.4 N - m at 8500 rpm
    Compression Ratio: 11.640.4 : 1
    Bore x Stroke: 58.0 x 58.7 mm
    Ignition System: TCI( Transistor Controlled Ignition )
    Starter System: Electric
    Transmission System: Constant mesh , 6 - Speed
    Lubrication: Wet sump
    Fuel Tank Capacity: 10L
    Oil Capacity: 1.05 L
    The MT-15 gets the same 155cc single-cylinder liquid-cooled engine that we have seen in YZF-R15. For MT15, the engine gets even more refined low-end torque. It generates 19.3hp power at 10,000rpm and 14.7Nm of torque at 8,500rpm. The motor is mated with a 6-speed gearbox.
    Since the engine is refined for more low-end torque, handling traffic and congested streets is a much easier task for the bike. This has been possible due to 52-teeth sprockets compared to 48 teeth on the R15. It helps in initial faster acceleration but after 100kmph, the R15 leaves MT15 far behind. The maximum speed we attained was 130kmph but the R15 can go above 140kmph. The bike gets telescopic forks at the front and a mono-shock at the rear which can save you from small potholes although harsh bumps will have no compassion on your back, it is always a trade-off!
    Ride & Handling
    The MT-15 is a clear winner for the city-like driving conditions. Riding in lower gears at traffic situation is not a problem for this bike. Second gear can reach 40kmph speed easily and its mid-range punch is striking too. The bike remains stable at lower speeds even on higher gears.
    The MT-15 gets VVA tech which adds some more power to the ride through its variable-valve-actuation technology - This helps with mid-range torque as well as maintaining excellent fuel economy as your ride the motorcycle. It also get a slip and assist clutch facility which reduces the chances of wheel locking. The bike only gets single-channel ABS however while R15 get dual channel which is just another difference between the 2 siblings. Cornering is not really an issue in this bike.
    Our Conclusion
    To sum up, it will not be wrong to say that bike is practical for all purposes and can astonish you with its striking looks. The bike can be used for day to day riding and even deliveries if you're up for it, and if you want nimbleness and fun bike then MT15 perfectly fits in your bracket. Striking good looks, excellent technology, and build-quality and warranty backed by the official Yamaha distributor in Singapore - What more can you ask for? (Cheaper COE probably..)
    P.S. You can watch this review from an MT-15 owner done by @Farhan Tre:
    User Feedback
    Recommended Comments
    Farhan Tre
    Hey y'all, courtesy and a huge thanks to Auto Exchange, a sponsor of both for myself & SBF, I've tried out the Yamaha MT-15 and give my review of it from a personal perspective!
    • Like 1
    Retired
    Performance wise still OK.  Been using the MT-15 for the last 6 months.
    As of now the thing I do not like about this bike is the left hand switch which is dangerous to use in my opinion.(B8D-H3972-00 Left Switch Holder)
    The horn button is so far off, its like non existence have to really look and reach for it, if not you would end up pressing the signal button.
    The newer V2 switch is even worst they corrected the horn issue but they created another one ,which is merging the high/low beam switch with the pass
    now you can only press the horn or pass switch, you cannot use both unless you are using your fist.
    Experienced riders knows you always need to have your index finger on the PASS switch and the thumb resting on the horn when riding.
    For those who are riding bikes with this type of switch I advise you to quickly change it, as you would really need the 2 secs that could save your lives.
    V2
    The best switch I've encountered is still from the RD350 YPVS long long ago. Those who have experienced this bike would know what I mean. Simple and solid but sadly you cannot find it now.
    • Like 2
    snooptrader
    V2
    Did you dismantle and actually swapped out your switch or you just adjusted to the controls of the bike? Thanks for the feedback..
    Add a comment...
