Think almost everyone is seeing a new thread now & then asking for help to a problem from someone new to SBF. Some might get harsh on them( Inclusive of myself at times, I apologise). So I was thinking we might as well start a list that will continue down what we should look out for in/on our bike if something were to fail and we try to rectify it. Moderators please feedback on this if it ain't appropriate or clashes with other existing threads.
Please copy the template and add on your recommendations with smiles
jB :]
For eg.
Problem - Exhaust emitting white smoke
Solution :
- Your bike is a 2 stroker, Ta 150
- Engine Oil mixing with your petrol ; piston ring worn out?
- your third solution/suggestion here
Problem - Your problem here
Solution :
jB recommends Planet Motorcycles if you need to diagnose/fix your bike
Planet Motor's address:
3007 Ubi Rd 1
#01-430 Singapore 408701
Tel/Hp : 67474740
UPDATED by jB
Solution: Its normal.
Turning the screw clockwise to enrich the mixture. (once again, tune in 1/4 or 1/2 turns of the air correction screw, located on the LEFT side of the carb)
Bike tends to rev rapidly but have poor acceleration if lean, and if too rich, will have "spongy" / slow throttle response at high speeds.
If in need of advise / demonstration sms pandora's kitten at 93270801 (advice/demo given is FOC)
Reason: Air leakages.
Reason: Air filter clogged.
Solution : Get your air filter changed. You are advised to inspect the air filter every 4000 or so kms and change it at 10k (Honda warranty service manual)
Solution 2: Buy a can of fix a flat from Carrefour or petrol stations, put it in your box.
Reason: Fuse may be blown.
Solution: Obvious.
Reason: Water in petrol
Others:
- Check magneto coil.
Solution: If you have very poor acceleration when throttle is opened, you are running lean. Enrich mixture by 1/2 to 1 turn of the air correction screw.
Solution: If you are using spray on chain lube, dirt and grease may be thrown off the chain during normal operation. When a lot of grease accumulates on the chain tensioner (rubber cylinder) and swingarm protector (rubber bar) the chain will emit a loud sound as though running through sand. Scrape and wipe away the excess grease and enjoy the quietness.
Solution:
- Send to bikeshop.
Solution:
- 67474740 Tiko cheong.
- 64560018 Wing Yap.
Reason: Gasket Spoilt.
Reason: Speedo spoilt.
Solution: Bike shop.
Reason: Clutch is worn
Solution: Fuel/air mixture too lean giving poor acceleration and a hot engine
Solution:Change new bearings.
Problem 21: Weak Battery.
Problem 23: IU Spoilt.
Solution: Fuel-air mixture likely too rich. Backfires when throttle is closed, due to residual fuel afterburning in the exhaust header. This is bad for the valves and the catalytic converter.
Solution: Do DIY exhaust wrap. Reduced backpressure = faster heat evacuation, leading to high speed silent running and silent cooldown after engine off. (Pandora's Kitten :3)
Solution: Gear box dying.
Solution: Engine is overheated. (Running too lean/ Not enough engine oil. An overheating engine may cause excessive oil consumption, especially when using less tolerant mineral oil)
Problem 27: Handlebar position is not centered (while riding). Handlebars are "straight" but wheel points to one side.
Solution: Lock the wheel, grab the handlebars firmly and twist the bars until straightened. The risers are flexible to some degree, due to the vibration damping rubber washers. (Demonstrated by Planet Motors)
Solution: If your steering lock is spoilt, put the wheel against a pillar or a wall.
Problem 28: Bike hard to U-turn. Riding position not comfortable as handlebars too high up.
Solution: Adjust the angle of the handlebars. Loosen the bottom two screws of the risers, pull back the bars so they "rise" towards your face. This will give you a more relaxed riding posture and you are able to enjoy a greater turning angle at low speeds. If your handlebars are set to rise straight upwards forcing you to stretch forward and upwards to steer, your elbows will prevent you from turning easily at low speeds.
Edited by jB
Because I'm jB :]
Solution :
Problem - Engine stalls in heavy rain
Solution :
- change plug cap
jB :]
Solution :
Solution :
- change plug cap
- spark plug could be wet, remove it to "dry" and try again.
Solution :
Solution :
- Change plug cap
- Spark plug could be wet, remove it to "dry" and try again.
- Might need to tune carb.
Problem - Flat / Punctured Tyres
- Try to inflate tyre with portable pump / bicycle pump then go bike or tyre shop. DO NOT ride on flat tyres as they may damage your tyre or wheel.
- Use tyre repair kit, plug and pump = good to go. Kit can be bought at LAB.
Problem - Cannot / Hard to start bike
- Push Start.
- Check Fuse. Fuse is located on right side of bike. Remove chrome cover under the seat and see. look out for the centre of the fuse if its broken then FUSED lor. change new one.
- Make sure bike is in neutral, Kill switch is not depressed, key is turned after inserted. If its none of these check if battery is working.
- Rectifier issue / battery issue- very common for phantom ta200 . get your mechanic to check with a voltage meter. ah chong has one.
- Petrol topped up too full - dont laugh. the petrol is not meant to be filled to the brim. but rather with some space for air.
- Water in petrol - could be the problem too
Problem - Cant go more den 80 km/h
- TA200 have 6 gears. Make sure you are already at top gear.
- Ensure that the correct amount of EO is put in.
- If confirm no 6th gear, go bikeshop check gearbox.
Problem - Weird sound on my bike
- Might be battery low.
- If sound is on gearbox side, check your chain tension 1st.. should be bout 2 to 3cm slack, tested at the center of the bottom span of the chain. Anything more, get it tightened.
Problem - Exhaust Header got holes. Can repair?
- Got one specific hole which is ok. If otherwise, post some pictures.
Problem - Engine oil Dip stick broken (Broken part might be in engine)
- Send to bikeshop.
Problem - I have tried everything but to no avail. Any tow numbers please?
Problem - Engine Part Leaking Oil
- Gasket Spoilt.
- Cam chain tensioner spoilt.
Problem - When riding, bike lean to one side. Let go of handlebar, steering was shaky and wobbling
- Might be steering cone problem.
- Might be bearings spoilt.
- Wheel alignment might have problem.
Problem - Speedo is not working
- The cable, or the gear at the end of the cable is spoilt or loose.
- Speedo spoilt.
Problem - My exhaust pipe got so sound (Backfire)
- Retune the carb.
Problem - I lost my bike Key!!! What to do??
- Go find keysmiths.
- If want to change ignition, look for Ah Chong (Planet) or scrapyard.
I merely compiled all the useful comments into point form. Credits goes to those who helped to answer these questions.
Solution :
Solution :
- Change plug cap
- Push Start.
- Send to bikeshop.
- Gasket Spoilt.
- Speedo spoilt.
- Retune the carb.
Problem - Bike pickup super slow. even slower than cars.
- change ur clutch plates.
Problem 2: Engine stalls in heavy rain and unable to start.
Reason: Air fuel mixture may be too rich.
Solution: Obvious.
Others:
Solution:
- Send to bikeshop.
Solution:
Solution:
:lol: this is a nice one, really got me laughing out loud. nice effort
SNapEl
Lol thx it was nothing. You guys provided the info, i just do some re-organising. Actually if can copy, edit and paste on to first post will be better. lol jB gotta keep updating his first post liao like that lol. Mod sticky can? lol
thats why my 2nd post was put as Reserved Post ;) but I forgot to create a few more just in case the max limit for one Post is reached.
Arghhh! don't sticky it so soon ;) because I realised I myself hardly notice the sticky threads side myself so I suppose some others won't too.. unless the sticky threads are much attractice and not so dull :rolleyes:
anyway thanks for the contributions. :thumb:
Well done bros...great post...
I have one...heh heh...problem, not solution...perhaps you guys can figure it out...
Today, when I was riding...something felt wrong between 2nd and 4th gears...when I shift down, the engine roared like the gear is too low...but when I shift up, the engine whines like the gear is too high...only when I hit 5th gear and up does it sound normal again...but when I reach the next light...the same thing happens again...fine at 1st gear too...but 2nd 3rd and 4th gears all sounded off...what could be wrong??
Will bring it to a mech tomorrow...but for now, anyone care to diagnose??
:btw: There is no charge for awesomeness... :goodluck:
bike after using for a few months feels like
getting less and less power (acceleration,
6th gear speed, etc.) how ah?
is it need to clean the air filter and spark
plug?
Probably your gearbox is whacked.. which mech you bringing to? careful dun kanna carrot. Best is if the mech can go a round with your bike then tell you whats wrong rather than just hear what you say.
plug?
When is the last time you changed engine oil, air filter and plug?
Basic maintenance:
Change EO every 2000km
Change Spark Plug every 4 EO changes
Clean air filter every 2 EO changes and change every 10000km
If basic maintenance is done, check chain if loose, tyre pressure, tyres not more than 5 years old.
hmm I don't have a solution to that but I'm thinking
1) throttle cable gone haywire? over rev by itself?
2) you're not at the right gear, somehow?
3) airbox? need some tuning?
4) problem with your gears?
plug?
you didn't change your EO/Air Filter/Spark plug? pump Tyre Pressure?
Basic maintenance:
I used to change monthly EO w/out hitting 2k at times :cheeky:
spark plug change every 2 EO change and filter per 2-3x EO change. Actually tyres shouldn't be more than 1 or 2 year old usage :goodluck:
Thanks bros for your answers...
Brought to a small shop mech, near my place...he rev rev engine, didn't even ride around...says no problem...
I rode around after...yeah, not as bad as before...anyway...since don't seem serious, maybe leave it till tomorrow...if have time maybe go to planet...
Thanks again...:)
solution 5) maybe it was just your mind playing tricks on you :cheeky:
if you have any more fear about engine and all, ah chong from planet motors would help you loads ;) but he's not god though, don't expect 100% cure :thumb:
Thanks again...:)
how old is ur bike?
when in 1st gear n fully clutch in does it felt like it wans to move off?
my suggest possible clutch plates worn out.
go get it checked.
http://i23.photobucket.com/albums/b370/shirsiak/shootout4.jpg
Riding is Like Fine Wine,It Gets Better With Age
Riding is a Passion That Glows n Never Will Fade
Riding is Like an Eternal Flame,Burning Passion Till The Very Last Days
how old is ur bike?
go get it checked.
No bro...nothing like that...anyway, didn't get off work till very late, so no chance to go to planet...next week first....
Thanks
Solution: Obvious.
Others:
Solution:
- Send to bikeshop.
Solution:
Solution: Obvious.
Others:
Solution:
- Send to bikeshop.
Solution:
Guys need help please, just now i was coming back home, bike was ok when weather still held...then the rain came...then my bike died when i stopped at traffic light at adams,after repeated tries still couldnt start so i called my friend, he say drizzling shouldnt stall bike but wait awhile then restart...it worked then after awhile at thomson it again died..did the same trick then died again at marymount before finally dying at bishan and then reach home AMK...all the times it died was when i stopped at traffic lights.
I have been riding the bike for 6weeks, never had this problem before, can the idle speed change by itself? or was it just the spark plug getting wet even though it was only a drizzle? i am taking bus to work tmr liaoz...sianz
12 Jun 2008 - Class 2B
28 Jun 2008 - Honda Phantom TA 200 (COE 11/3/17)
17 Jan 2009 - Class 3
27 Oct 2009 - Class 2A
28 May 2016 - Yamaha Fino 115 (COE 04/8/24)
9 June 2017 - Honda CB400 Spec 2 (COE 02/1/23)
Don't you think your issue is very similar to that as stated in Problem 2? zzz the answer is there! If your bike can start tml morning you can be doubly sure liao. zzzz. If you totally not sure or dun wanna think, pay $ tow to a mech and pay tuition fee lor
